korting: SB7440W; Transmare 38
28.Jun.04 22:54
Jose Vigil (RA)
Articles: 62
Count of Thanks: 11
Jose Vigil
I am restoring a transmare 38.
The set uses a voltage regulator tube. It was not present. From information I collected, it is a 150 Volts gas regulator.
For the time being it was replaced by an OA2.
I will apretiate information on this regulator (Number and specs.) and the possibility to find one of them.
Also very interested to interchange opinions on this model.
Jose
New august 20 2004
I finished the chassis. It is working fine in all functions.The case has been restored too.
The following list is of items needed to complete the restoration:
1. Rear view to reproduce the rear cover which is missing.
2. View of the speaker switch wich is broken, to reproduce the original shape.
3. The knob that controls the function of preselected radio stations. Missing
4. The regulating valve. Is a 150 Volts bayonet socket. (similar in specifications to the OA2)
Any help will be apretiated.
Jose
30.Jun.04 20:35
Robert Sarbell † 22.3.22 (USA)
Articles: 358
Count of Thanks: 13
Jose,
I presntly have 6 or 7 0A2 regulator tubes. . .some Raytheon, Western Union (the telegraph company of years ago), and I believe also a Mullard version.
Will contact you directly if your profile is current.
Robert
16.Jul.04 05:55
Jose Vigil (RA)
Articles: 62
Count of Thanks: 11
Jose Vigil
Hi Robert
thanks for your kind reply.
I have already installed in the set an oA2. To do this I replaced the original socket.
Wath I'm looking for is the original.
Best regards, Jos
