Magic Eye
? Magic Eye
28.Jul.12 19:47
Mujahid Khan (USA)
Articles: 26
Count of Thanks: 14
Mujahid Khan
Hi:
Is there a substitute for the magic eye tube EM34.
The EM 34 sells for 79 dollars, which is expensive to me.
Thanks
M Khan
6e5s
28.Jul.12 20:45
14 from 4355
Michael Watterson (IRL)
Articles: 1126
Count of Thanks: 14
The Russian 6e5s works well enough in my Pye JH/E as a replacement.
It's a bit more sensitive, so you might add a series resistor 2M2 Ohm and parallel resistor 1M ohm on the grid to reduce it. I didn't on my Pye.
The wiring of the base (see article) is slightly different. Either re-wire base or use an octal plug and socket wired as an adaptor.
Most magic Eyes can be "somehow" replaced by just 3 Russian / Chinese types
See article
All Octal end view types by Russian 6e5s, 6e5G etc
All side Noval bar types by Russian or Chinese 6FG6, 6E3P 6E2
All Noval fan/ Angel wing by Russian or Chinese 6e1p, 6BR5
Wiring changes or adaptors may be needed!
Damage can result by direct replacement!
Thanks sir.
30.Jul.12 01:25
99 from 4355
Mujahid Khan (USA)
Articles: 26
Count of Thanks: 18
Mujahid Khan
Dear Mr Watterson:
As usual, I am indebted to you for the clear, timely and detailed answers. Your help goes a long way for the learners.
Thanks
M Khan
UM4
11.Aug.12 19:19
269 from 4355
Bryce Ringwood (ZA)
Articles: 78
Count of Thanks: 14
Bryce Ringwood
Hi,
I've been using the UM4 - a 12 volt tube with a small filament transformer. It has the same general shape and appearence to the EM34, and is also dual sensitivity. I managed to get some at a bargain price. The base has to be rewired. - See the tubes in  the RmOrg tube collection.
- Bryce
