magnavox: 5801AA; FM-017
21.Aug.09 17:56
Lynn Hatfield (USA)
Articles: 4
Count of Thanks: 8
The wave bands on this radio are: AM, 550 to 1650 KHz and  FM, 88 to108 MHz.
Please put this to the model
21.Aug.09 18:59
Officer
Articles: 5747
Count of Thanks: 5
Dear Lynn
Fine that you help to complete models. It is your first activity here and we like that you begin to care for RMorg.
At the same time I beg you to click the model (above), then below on the link bar where you found "Add information or ask a question" to write - but you click "Suggest change". Then you get either the history of a model and can click for the entry form - or you get the form directly.
You then can select for the two (?) wave bands and you can add your text to the notes.
When I do this then I repeat the model name to get it a better chance for searching machines, putting the data into sentences.
I see that also the loudspeaker has not a good setting ...
After you have done so you can see what the model admins do with it if you go to the link below "Community" called "Pending Models".
I hope you don't face any difficulties. Have you tried the Schematic Finder for your other question? I have put in 5801 and found this model. Perhaps this helps? If yes, I would like to delete that one. Maybe we have to take more actions about the two Magnavox?
Thank you for your cooperation.
