marconi: T23BT (T 23 BT);
Dear Experts,
Is there more than one version of this receiver? According to data in R&TV Servicing the T23BT is a 6 Volt powered set not ac mains. The 23 Series is stated as being a UK export range:-
T23AE, T23AT a.c. mains powered.
T23DAE, T23DAT, a.c. and d.c powered, using the 142 series tubes.
T23BE, T23BT, 6 volt powered with self-rectifying vibrator. This also has a push-pull output stage with a pair of N151 rather than the N150 mentioned in our data. (The N150 is used in the ac sets.)
The E versions have a long-wave band in place of one of the four Short-wave bands on the T versions.
There are a few other discrepancies in the details so it would be good to clarify and correct if possible.
Regards,
Roy
