metrix: 310-D ; Lampemetre
Count of Thanks: 8
Hello!
I'd like to know if this tester is a mutual conductance one.
Regards
METRIX 310
Yes, it is. You need to change grid potential by 1 Volt and measure the plate current difference. It's a very robust product, well appreciated in France by collectors,
Christian
grid shift method
Hi Mr. Adam,
the maoeuvre you're describing is called 'grid shift method'. This cumbersome procedure requires manual interaction and calculation of transconductance. In addition, using a large delta Ug1 (you're mentioning 1 Volt) results in an average transconductance over this grid range (problem: secant vs. tangent). Also the best German tube testers (e.g. Neuberger 370/375) are restricted to this indirect method of measuring transconductance.
In contrast mutual conductance measurement is automatic. This case the grid is modulated using a small sine wave signal of either the line frequency or a considerably higher audio frequency (e.g. 1400 Hz) of constant amplitude.
Kurt Schmid
OK
Thanks for the accurate answer. Because I was not sure, I prefered to describe to procedure. But it's really not complicated doing this this way,
M f G from France
