mil-gb: R-1155;
mil-gb: R-1155;
22.Dec.06 19:39
5768
Bo Samuelsson (S)
Articles: 23
Count of Thanks: 12
Bo Samuelsson
RECEIVER MARCONI R1155 OVERVIEW
History
On order from the Air Ministry (AM), Marconi Wireless Telegraph Company in 1939 started the development of a transmitter/receiver system, the T1154/R1155, based on the AD77/AD6872 which was used in passenger aircraft. By that time Marconi was the leading manufacturer of aircraft radio in England and perhaps in the world. The system was intended for use in heavier military aircraft, and during the second world war it was used in light bombers like the Blenheim and Mosquitio, and in heavy bombers like the Stirling, the Halifax and above all the famous Avro Lancaster.
In the beginning of 1940 the Ministry of Aircraft Production (MAP), accepts the design and the first production set is installed and tested in june that year. Marconi has the overall technical responsibility and E K Cole (Ekco) is responsible for the production. Plessey and EMI are also producing in addition to Marconi and Ekco.
The R1155 was manufactured as models R1155, R1155A, B, C, D, E, F and L, M, N. Of these models R1155, R1155A, B, C, D, E and F were intended for use in aircraft. Model R1155 had no filters, A had the IF traps added and B also had the radar filters. D, E and F were the corresponding receivers with steal case instead of aluminium. C was a model with direction finding circuits working on HF, was taken out of production early, and L, M and N were used in ground stations and vehicles, and in sea vessels for the Coastal Command. When the war finally ended more then 80.000 R1155´s had been delivered!
Receiver Data
The R1155 is a single super with one HF stage and oscillator/mixer, a total of three tuned circuits, and two IF stages. With detector, BFO and AF stages there is a total of 6 valves plus a magic eye as tuning indicator. There are facilities for direction finding and homing and the D/F part has 3 valves.  The set covers 75 to 1500 kHz LF/MF in two bands and 3 to 18.5 MHz  HF in three bands. Bandwidth is 5 kHz @-6 dB and the sensitivity is better than 10 uV on all bands.
Although rather simple the receiver has a remarkably good performance for short and medium wave world radio listening.
My Receiver
I had an R1155 in the end of the 1950s and used it for DX-ing. I eventually sold it when I got married and had children. Now I am retired and I recently bought another R1155 which I have restored to its original state and again I use it for broadcast station DX-ing. The receiver was nearly untouched and after adding the DF valves it is like it came from the factory, probably in 1943. It is an R1155 modified to the A model by retrofitting the IF filter traps. The serial number is 32343.
Further info on my home page http://goto.glocalnet.net/bosradio
