military: BC-458; Command SET
10.May.10 12:08
32
Jan Terranea (NL)
Articles: 63
Count of Thanks: 13
Jan Terranea
Command Set is not a model name, but a general name for the small, light and compact aircraft receivers and transmitters that are part of SCR-274-N, ATA/ARA, and AN/ARC-5 radio-equipment.
Model change submission
10.May.10 18:02
32 from 3197
Emilio Ciardiello (I)
Articles: 527
Count of Thanks: 14
Emilio Ciardiello
Dear Jan,
you are giving right information but it would be better to submit a model change form rather than enter a forum thread. In this way a panel of administrators can evaluate the proposal and definitely modify the card of the model.
You can try to select the 'Model change' option from the 'Uploads and questions' menu. Then you must click on the  'Suggest a change' link. and propose your suggestions in the next form.
Regards, Emilio
