montgomery:  ; 25GSE-1555A (25 GSE 1555 A)
? montgomery:  ; 25GSE-1555A (25 GSE 1555 A)
01.Nov.09 14:05
John Backscheider (USA)
Articles: 4
Count of Thanks: 24
John Backscheider
After initial recapping of this Ward Airline radio, it exhibited signs of silver mica disease.  Attempting my first repair on an IF Transformer, I have some questions which I hope you can help me with
1.  The schematic shows two mica caps but only gives one overall value 250mmf  which covers both.  How can I determine the individual values I should use for my two replacement caps? 120 pf each?
2. Removing the internal componets to get to the original mica caps, I made a rooky mistake and broke one of the two fine wires that run up the side.  The wire gage is very fine.  Should I solder a replacement length of wire I have available (24 Ga) or is there another way to properly repair this?
Thanks and I hope you can help me.
Filter caps
01.Nov.09 15:54
Articles: 2316
Count of Thanks: 31
 Just by trial and error:
 I would install two 120 caps and see if I can tune an IF maximum. If that fails, two 250 caps should do the job.
Good luck!
