nordmende: 1/616; Caruso-Stereo
17.Oct.04 04:07
Robert Sarbell † 22.3.22 (USA)
Articles: 363
Count of Thanks: 11
For what main reason is the 0,2 Cu Heiz-sicher placed at this point on the filament heizung portion of Netztrafo - as depicted on schematic?? Is fuse placed between pins 4 or 5 of EL84 and ECC85??
mfg,
Robert Sarbell
Cu -Wire in Filament -Cicuit off Tubes
17.Oct.04 12:31
Articles: 2165
Count of Thanks: 7
Hello Robert,
nice to meet you.
Here my answer:
This 0,2 mm Cu wire, is the "Fuse"  to protect the  Cu-connections " Leiterbahn" on the Printed Board. The Power Transformer is able to deliver more then 20 Amps in this case: a Tube makes an Shorting inside of the Bulb, or the Condensor C 136 on the  EABC80 have a shorting.
The high current from Transformer destroys the only 35 um Cu -Foils on the PC-Board.
The 0.2 mm Cu Wire in the Set, prepare a <designed disconnection>  (in german = Sollbruchstelle)  to prevent this Trouble.
I hope you understand.  In Grundig Sets you can find this Versions off Fuses
Greadings from Frankonia, Hans M. Knoll
Fused protection of Printed Circuit board
17.Oct.04 16:17
Articles: 363
Count of Thanks: 7
Guten Tag Hans,
Thank you so much, I fully understand the rationale. I have not worked with many tube radios that use the printed circuit boards. Most always the point-to-point wiring connections of the older receivers.
Robert
