nordmende: speakers wire connections
? nordmende: speakers wire connections
Respected members.
I am asking specially to the Tannhäuser 57 radio owners, about the speaker's wires connection over the output trafo.
I am restoring a set who arrived with the six wires unattached to the five pins plate over the output trafo.
I have not been able to properly identify the pins where they need to be soldered again. One of the speakers, the electrostatic tweeter, has 192 volts to operate. A wrong connection can burn the other speakers.
I will be very thanked if a kind member can send a diagram o photos showing the speaker's wire connections.
Thanks in advance,
Bruno.
Tannhäuser 57 speakers wire connections
Hallo Bruno,
alignment instructions
Hello Wolfgang,
Thank you so very much for the quick answer. With the color code secondary windings it will be easy to solve the puzzle.
Now I saw the alignment instruction. l it will be very usefull for me also.
Thank you again,
Bruno.
