philco: 39-36XX (39-36) dial glass restoration
This article refers to the model: 39-36XX (Philco, Philadelphia Stg. Batt. Co.; USA)
18.Aug.10 08:43
7688
Radio friends,
If the white lettering is flaking off the dial glass, it can be restored as described below.
- The original appearance of the dial glass, with a lot of missing pigment:
- The lettering on this dial glass, unlike that of many other Philcos, is not screen printed, but is embossed into the back surface of the glass and filled with white pigment. The remaining original pigment can be removed by washing and brushing, leaving the clean glass surface with only the embossed depressions for the lettering and lines. The entire back surface can then be painted with an off-white color to match the original color of the lettering. Scraping with a razor blade then removes the paint on the surface, leaving the embossed features filled with paint:
- After scraping the entire surface, all of the original lettering and lines are visible:
- With some further masking and painting, the wide wide stripe at the bottom can be painted to match the original:
- Closeup view of the lettering, showing the quality that is easily achieved:
The embossed lettering produces a very nice effect when viewing the lighted dial on the radio in a dark room. Dial lamps light the left and right frosted edges of the glass, sending light through the glass which illuminates the features, with enhanced brightness at the feature edges. Very pleasing effect.
Use of embossed lettering is not unique to this Philco -- I have seen it on a number of European radios as well. This type of dial lighting is common on molded plastic dials, but not so common on glass dials on American radios.
