philips: 22RR522; Globetrotter 522
This article refers to the model: Globetrotter 522 22RR522 (Philips - Österreich)
? philips: 22RR522; Globetrotter 522
03.Sep.10 14:36
39
Felice Nicolini (I)
Articles: 13
Count of Thanks: 12
 Good afternoon.
I have photos of the model indicated in the title, but could instead relate to the corresponding German model  Radio Recorder 522. I see no evidence, neither on Radiomuseum nor on my equipment, for a safe assignment. Within the first radio cassette, is on the plate: "Type: 22RR522/19R", while on the variable capacitor is the label:
TC05 22RR522/19R,
460KC 74 425
163509.
The other radio cassette:
TC02 22RR522/19R
460KC 77 342
39631.
Thank you
? 22RR522
03.Sep.10 19:16
39 from 4654
Articles: 2327
Count of Thanks: 9
Hallo Mr. Nicolini,
can you see where the device was built?
Made in Austria, Germany or Netherland?
Regards WB.
? 22RR522
03.Sep.10 20:26
58 from 4654
Felice Nicolini (I)
Articles: 13
Count of Thanks: 11
Behind, on the right, where the handle at rest stops, there is written, very small- on the boths radio recorders- "made in Holland".
What do i do?
Thank you.
22RR522
04.Sep.10 00:06
93 from 4654
Articles: 2327
Count of Thanks: 25
Please create a new model built by Philips Nederland.
Regards WB.
? 22RR522 on Philips Holland?
08.Sep.10 20:56
176 from 4654
Felice Nicolini (I)
Articles: 13
Count of Thanks: 17
Thanks for the answer.
I doubt however, that following this path the number of models from Philips will grow much. For example, I have two radio cassette:
-22RR622/59
with little written on the bottom, outside, "MADE IN HOLLAND";
-22RR645/19
marked "MADE IN HOLLAND" on a label near the battery compartment.
Now, you can verify that one is currently logged -on Radiomuseum-
 on Philips Deutschland and on Philips Oesterreich, while the latter only on Philips Oesterreich. Neither is currently recorded on Philips Holland.
Thank you.
Philips Models
09.Sep.10 00:01
198 from 4654
Articles: 2327
Count of Thanks: 9
Never mind.
Especially for Philips, there are many production sites.
Each new country of production of a model must be documented.
Please place your three new devices to Philips Holland.
Regards WB.
