philips: 526A;
Cet article fait référence au modèle : 526A (Philips; Eindhoven (tubes international!); Miniwatt)
philips: 526A;
12.Mar.08 20:37
Jean Laurent Niel (F)
Articles: 2
Remerciements: 25
Tube line-up
13.Mar.08 16:56
Conseiller
Articles: 1681
Remerciements: 10
Welcome to the Radiomuseum and thank you for your input!
The mentioned tubes should be added to the model-page. You can do this yourself by clicking 'Suggest change' (in french languange: Proposition de modification). Next page, you can fill in the tube list. Use only spaces between each tube, no comma or semicolon. List the tubes in logical order from antenna to loudspeaker, rectifier at the end. If a tuning indicator tube (magic eye) exists, put it on the 5th place. This is a general rule in Radiomuseum.
Your proposal will be checked by our admins and if correct afterwards accepted
Try it. It's easy!
Regards,
