philips: 593A
philips: 593A
Count of Thanks: 9
1) Tubes are:
AK2-P
AF3-P
ABC1-P
AL2-P
AZ1-P
8056-38 dial lamp
2) Dimensions (WHD):
300 390 230 milimeters.
3) Power Type and voltage: 220 volt AC only
4) Made in Argentina, year still unknown
Model change suggestion
Dear Jorge Mochkovsky,
thank you for these important additional data! You can add them, as every member, directly to the model page itself.
To do so, move the mouse over the field "Uploads and questions" located at the top left at the model page. A pull-down will open, choose "Model change etc" and click.
The next window shows the changes history, clicking the link "Suggest a change" will open the input page where all data can be filled in.
When completed, please specify the source where the data comes from. Click "GO", check once more your changes and send them if all is ok.
That's all, it's the best way how RMorg members can complete missing things at each model.
Good luck and welcome to RMorg!
