philips: Philips 855x
? philips: Philips 855x
Helllo Can someone in this forum give some info i know there were diffirent intermedia freq like 468,or 473kHz .This set peaks the IF at 495kHz, Can someone tell me if this is normal Any info gratefully received Greger
The Philips service documentation specifies the following IF values for model 855X and versions (made in the Netherlands or Belgium):
- standard version 855X: 473 kHz
- 855X-19 and 855X-32: 452 kHz
- 855X-20: 444 kHz
Trader Service Sheet 465 specifies 470 kHz for a model 855X (obviously made in GB).
Regards,
Gidi
Thanks for all the info Regards Greger
