philips: Philips B7X14A Model variants
? philips: Philips B7X14A Model variants
Count of Thanks: 5
Hi, last month I bought a B7X14A/09, but I cannot find any information on the 09 variant, I bought the radio in Sweden, and it all works well apart from the volume pot crackling a bit at the lower end of the range.
Any information would be greatly received
Thanks
Hi Marc,
Congratulations with your Philips B7X14A /09.
This version is not yet represented in our database, so you are requested to create a model page for this version. Make sure also to upload a picture of the type label. This label will tell whether your model was made in the Netherlands, Belgium or elsewhere..
Maybe printing on the chassis shows what the IF of this version is.
Good luck,
Gidi Verheijen
Hi,
There is also a model B7X14A/62.
Unfortunately I cannot create the model.
Greetings WB.
Hi, here is another model from this series, the B7X14A/22.
Unfortunately I am not allowed to create models.
WB.
Hi, here is another model from this series, the B7X14A/03 Philips Belgium/Leuven.
This model does not exist in RMorg either.
WB.
Hi,
There is already a thread which tries to compile Philips variant codes, it is located here .
Maybe the model Reverbeo B7X14A /00 /01 - Philips Belgium could be created separately, as it differs in appearance, scale, etc.
See pictures.
WB.
What I also noticed is that the model B7X14A /65 is not made by Philips London but in Belgium.
Note the picture with "PL" for Philips Leuven.
WB
