philips: EL3517; Repairs to switch SK4.
? philips: EL3517; Repairs to switch SK4.
03.Feb.13 13:47
2032
Kenneth Cooke (AUS)
Articles: 12
Count of Thanks: 6
Kenneth Cooke
Switch SK4 which I believe switches the record/replay head from play to record, is badly damaged. Feedback on how to best repair this will be appreciated.
My options are to rebuild the switch, replace with a microswitch or to bypass the switch in permantly replay position.
To rebuild would be more authentic but problem is to find the raw materials. The metal required would, I believe be either phosphor bronze or beryllium copper sheet. The cheapest I can find is about GBP80 for a 25mm x 25mm x 0.5mm piece of metal from Goodfellow or I could obtain a piece of unknown type of metal from the spring strip contact from a 4.5volt lantern battery(not generally sold in Australia).
This picture is a closeup view of the mangled switch removed from its mounting position. The middle leaf of the switch is snapped off and lost. A second contact is badly bent.
SK4 switch close up view of switch removed from mounting position.
Next is over view of switch mounted in position.
SK4 switch over view mounted in its udual position.
