philips: Please check documents.
To the administrator.
At your convenience, please check two of the document pages. The first is, the schematic. The second page is of the top of chassis part locations.
document
Hello Paul,
yes this is a faulty document. As the graphics are merged together as one object within the pdf, there is no chance to separate them. You could ask the uploader Iven Mueller, if he can upload a better version. Other RM Members might have copies of this schematic, you could ask Walter Groer for example and/or activate the "I need this schematic" search function at the model page. This will be visible for the German speaking community as well.
respectfully
Martin
? Longwave external antenna connection not working. HELP PLS
Marin,
? Is this the correct Antenna Coil part number?
The bottom coil is S16 and its slug to peak 155.5khz long wave band. It will not peak. This coil is between the external antenna connector and the ECH81 first stage RF. When this coil is out of the circuit, as when the internal antenna is used the LW receives OK. No upper harmonic BC stations.
Comparing the part number with the list on the Alignment page they do not match. It seems highly unlikely this coil was replace with a wrong resonant frequency unit. It passes signal when screwed all the way in. It also passes harmonic frequencies from the BC band.
I opened up this coil to check. And it looks ok. The coils line up on the correct solder lugs. The slug is moving in and out with the set screw.
The antenna switch checks out OK. I used the B7X82a diagrams that matched just about perfectly.
I am at my wits end. Any ides on how I should proceed?
schematic fixed
The damaged schematic is fixed, now there are two parts of this schematic without faults.
I have acquired a good signal peak for S16
