olympic: Phono jack type
? olympic: Phono jack type
11.Dec.20 13:45
39
Mark Pennington (USA)
Articles: 49
Count of Thanks: 8
Hello all:
Does anyone know if there are cables available for this 2 pronged phono jack?
Thanks,
Mark
11.Dec.20 19:56
39 from 2222
Júlio Branco (P)
Articles: 206
Count of Thanks: 10
Júlio Branco
Olá
Para uma ligação à entrada de som nesse tipo ficha, basta ser um cabo de um condutor blindado, em que a blindagem do cabo será ligado à massa, (chassi), veja o esquema do rádio, numa das pontas do cabo ligue duas fichas tipo banana, na outra ponta ligue um jack compativel ao equipamento que queira que o som saia, (output).
Não sei se o administrador se vai zangar de eu colocar aqui um link para você procurar o que pretende, mas vou arriscar: aqui encontra tudo o que é necessário para fazer essa ligação:
Infelizmente o Rmorg não aceita links fora da plataforma do radiomuseum.
Tem outra variante, no google em "procurar" escreva: Shielded one-wire cable, encontra assim tudo o que pretende inclusivamente os Jack de várias medidas.
Cumprimentos
Júlio Branco
11.Dec.20 20:04
41 from 2222
Júlio Branco (P)
Articles: 206
Count of Thanks: 6
Júlio Branco
Hi
For a connection to the sound input in this type of plug, it is enough to be a cable with a shielded conductor, in which the cable shield will be connected to ground, (chassis), see the radio diagram, on one end of the cable connect two type banana, at the other end connect a compatible jack to the equipment that wants the sound to come out (output).
I don't know if the administrator will be angry that I put a link here for you to look for what you want, but I'll take a chance: here you will find everything you need to make that connection:
Unfortunately Rmorg does not accept links outside the radiomuseum platform.
There is another variant, on google in "search" type: Shielded one-wire cable, so you can find everything you want including Jacks of various measures.
greetings
Júlio Branco
11.Dec.20 23:18
57 from 2222
Articles: 49
Count of Thanks: 5
18.Jan.21 22:21
202 from 2222
Articles: 49
Count of Thanks: 10
As a follow up to this if anyone is interested, I found a good video on how to make a stereo to mono cable on the Electronics old and new by M Caldeira Youtube site.
