racal: RA-1772 (RA1772); variants
17.Dec.06 15:02
7817
Martin Bösch (CH)
Articles: 612
Count of Thanks: 36
Martin Bösch
the complete designation of RA 1771 and 1772 receivers alows to identify the mounted optional components:
format as follows:
1st suffix / 2nd suffix / 0 / fourth suffix / fifth suffix / sixth suffix
1st suffix: filters fitted (6 available slots)
A: symmetrical 0,3 / 3 / 8 kHz, sideband filters USB 3 / LSB 3 kHz
B: symmetrical 0,3 / 1 / 8 kHz, sideband filters USB 3 / LSB 3 kHz
C: symmetrical 0,3 / 1 / 3 / 8 kHz, sideband filters USB 3 kHz
D: symmetrical 0,3 / 1 / 3 / 8 kHz, sideband filters USB 2,7 kHz
E: symmetrical 0,3 / 3 / 8 kHz, sideband filters USB 6 / LSB 6 kHz
F: symmetrical 0,3 / 1 / 8 kHz, sideband filters USB 6 / LSB 6 kHz
G: symmetrical 1 / 3 / 13 kHz, sideband filters USB 6 / LSB 6 kHz
H: symmetrical 1 / 3 / 8 kHz, sideband filters USB 3 / LSB 3 kHz
2nd suffix: frequency standard fitted
0: no internal frequency standard, external frequency standard required
S2: type 9400 frequency standard
S3: type 9420 high stability frequency standard
3rd suffix: always 0
4th suffix: ISB filter identification
0: not required / not available
B3: 3 kHz Filter (2,7 kHz minimum bandwidth)
B6: 6 kHz Filter (5,7 kHz minimum bandwidth)
5th suffix: frequency shift keying
0: FSK facility not fitted
F: FSK facility fitted
6 th suffix: automatic frequency control
0: AFC facility not fitted
C: AFC facility fitted
Similar receivers:
RA-1773 (RA1773): RA-1771 fitted with MA-1070A connector panel providing a fan and front connectors of rear sockets, all in Creeth Field Transit Case.
Similar receivers:
RA-1774 (RA1774): RA-1772 fitted with MA-1070A connector panel providing a fan and front connectors of rear sockets, all in Creeth Field Transit Case.
