rca: RCA Radio model 28 T Capacitor List
? rca: RCA Radio model 28 T Capacitor List
![Keith Hardy](https://www.radiomuseum.org/image.cfm?image=me2a.jpg&width=120&height=140)
I am in need of a listing or cross reference of modern capacitors for a RCA Radio model 28T. The list in the schematics does not have the voltage values for each capacitor.
Thank You
Capacitor replacement suggestion
I think that you are going to replace all paper and electrolytic capacitors in the radio. When looking at the schematic, I would suggest the following:
All smaller paper capacitors (up to 100 nF), can be replaced with polyester capacitors rated for 630 V, although 400 V would be enough for all but C39 and C40 (those two capacitors will be subjected to the sum of the radio's B+ voltage and the peak AC voltage across the output transformer's primary winding).
Use 400 or 450 V parts for electrolytics C22, C37 and C41. For C38, 35 V is enough.
It is normally not necessary to replace the ceramic or mica capacitors used in the RF and IF tuned circuits.
Best regards
Torbjörn Forsman
