Refinish 1954 Grundig 4010 cabinet
? Refinish 1954 Grundig 4010 cabinet
HI,
I have a Grundig 4010TB radio with water damage on the top and front of the cabinate. The damage is only in the finish, the wood is not affected. I am looking for adivce on how to remove the damaged finish and what product to use to refinisg to match the rest of the radio.
Thank you
Count of Thanks: 21
Sir,
I found a stripper, CITRISTRIP, Paint & Varnish Stripping Gel. Purchased it at Lowes Home Improvement. Using it on my Silvertone 6362 to remove the old finish. Applying it lightly and using a green stripper pad like the one used in the kitchen to clean pans. So far applying lightly, waiting about 5 minutes, using the pad and then a soft cotton cloth to remove the residue is working well. I taped plastic wrap over the front to keep the cabinet cloth, which is somehow in excellent condition, from being stained.
Addtionally, at this link in the forum is an excellent artricle on restoring wooden cabinets:
www radiomuseum.org/forum/wooden_radio_cabinet_restoration.html
Sincerely,
Mike Nettrour
