grundig: routing of dial cord on a grundig 3262
? grundig: routing of dial cord on a grundig 3262
I need help with my Grundig 3262 radio. The tuner dial string has come off and I can't seem to put it back on. I do not have a schedmatic or any other pictorial info on this unit. I would appriciate any help that is available.
![Bernhard Nagel](https://www.radiomuseum.org/image.cfm?image=bn_profil_31_12_17.jpg&width=120&height=140)
Hi Leo,
welcome to RMorg and a hapy new year ***2021***
We have two similar models listed, the US-version 3262U and the German domestic 3262. The latter one has a stringing diagram for the dial cord, please refer to the 3rd pdf document.
Maybe also the schematic will help you to get this radio back to work, although the speaker amplifier has an ELL80 instead of two separate EL95 your model might has.
Check also the Sams schematic from the US-model, this could match closer to the Canadian model.
Please make some good pictures from your radio, inside and outside, (we only have pics from an kiiji offer until yet..) and list the tubes by a change suggestion.
Thank you and good luck!
