saba: 125-Stereo; Freiburg Vollautomatic
This article refers to the model: Freiburg Vollautomatic 125-Stereo (SABA; Villingen)
22.Jan.08 12:47
Bryan McAlley (GB)
Articles: 38
Count of Thanks: 14
As this radio has no stereo decoder, what happens when you press the "stereo" button on VHF? On mine, the volume drops, but I can hear no other change in the sound quality.  Bryan
22.Jan.08 16:26
Martin Renz (D)
Officer
Articles: 579
Count of Thanks: 13
Martin Renz
This function is for listening records in stereo only. You get two separate channels from record/line input to the loudspeakers. The center tweeter is turned of, when stereo is pressed.
Martin
23.Jan.08 01:01
Bryan McAlley (GB)
Articles: 38
Count of Thanks: 21
Martin - thanks! That makes sense. I now realise that I shall have to find one of the very last Freiburgs (an 18) to have pure stereo sound!! Bryan
25.Jan.08 21:23
Mike Izycky (GB)
Articles: 70
Count of Thanks: 23
Mike Izycky
Bryan,
you could go for a Freiburg 14 - they have a decoder as an option if I recall correctly, mine was ready fitted with one but you can always find one to fit later if you find a Freiburg 14 without one.
If I recall correctly, on some of the earlier stereo Freiburgs switching from stereo to mono changed the configuration of the output stage from 2x single-ended output stages (for listening to stereo records/tapes, as Martin said) to a mono push-pull output stage.
Regards,
Mike.
25.Jan.08 22:47
Articles: 2120
Count of Thanks: 17
Hello Mr Izycky
This function has, Fribourg's 125 Automatic, exactly.
Stereo 2 x single ended (for listening to stereo records/tapes)
Mono (Radio) Ultra-Linear push-pull mode l
 mfG knoll
26.Jan.08 01:37
Bryan McAlley (GB)
Articles: 38
Count of Thanks: 19
Hello Mike!
What a small world! I bought a Bush radio from you several years ago and am a big fan of your Bush site!  Thanks for the advice - I've got my eye on a Freiburg 18 at the moment and, if successful, will probably sell the 125. All the best, Bryan
12.Mar.08 18:47
Bryan McAlley (GB)
Articles: 38
Count of Thanks: 15
Well - I now have a Freiburg 18 with a stereo decoder which works very well, but I much prefer the appearance of the 125! So - can I put the chassis of the Freiburg 18 into the case of the 125 so that I get the benefit of the later technology within the older case??
Bryan
