saba: 310WL;
This article refers to the model: 310WL RENS1204 (SABA; Villingen)
saba: 310WL;
22.Oct.07 00:41
Donald Cochrane (USA)
Articles: 84
Count of Thanks: 13
If someone has worked on this set,  I would love to talk to them.  I am having a small problem with mine and would greatly appreciate the help.
Regards,
Donald Cochrane
EE 3.Nov.07: Deleted the eMail-address. Please never put in eMail address to the forum.
First you get SPAM
Second: Your eMail-Address is accessable for members only below and on your profile.
Specify your problem please
27.Oct.07 13:38
Articles: 2441
Count of Thanks: 20
Dear Donald,
if you could specify your problem, help certainly will be possible.
Best regards,
Dietmar
310W/WL
06.Nov.07 03:28
Articles: 84
Count of Thanks: 11
Thank you for your reply.  I am having trouble with two parts.  First, on the condensor block, is marked 5=/300   80=/1000   10=/300   200=/750   300=/1000   This is not marked anywhere on the schematic so I am having some trouble tracing condensors.  Someone was in this set before me and moved a wire so I also have to find out where it goes but that is a second problem.
Best regards,
Donald
Condensator Blocks
06.Nov.07 12:40
Articles: 2441
Count of Thanks: 13
The 310W/WL contains 2 condensator blocks, one above the chassis part No 320/70 and one below the chassis part No 324/8. Seen from the front of the chassis, the 311/70 is on the left hand side and contains 4 condensators, and the connections are from left to right:
  • C1; C2; C3; common of C1,C2,C3; C4; C4;  C1+C2+C3+C4 = 12,2 μF; 750 grams;
From the same point of view, the 342/8 which also contains 4 condensors, has the following connections:
  •  C5; C6; common of C5,C6,C7,C8; C7; C8; C5+C6+C7+C8 = 6,5 μF; 360 grams;
Unfortunately, the original Saba service sheets contain only this information, and there is no correspondence table to the No of the condenser and its value.
Extra condensors are
  • 311/71: 2*0,1 μF/500V; 312/69: 0,2 μF/1500V; 311/69: 0,5 μF/500V; the voltages being test voltages only
Hopefully, you can figure out which block contains which condensor.
Best regards
Dietmar
310W/WL condenser block
10.Nov.07 20:30
Articles: 84
Count of Thanks: 15
Now I am confused..  I have only found one tubular condenser on top of the chassis (I am guessing is the 8mfd) and the condenser block on the bottom.  I found my second problem with the help of a local friend and found the "problem" to be very interesting and A-typical of radios repaired during of just after the war.  Whoever worked on this evidentally could not get a replacement output tube (RES164) to replace a very used one so, he put full B+ on the plate to get a little more use from it.  I have replaced that part of the circuit and the set is playing now with a new RES164.  The question about the bottom condenser block still remains but,  fortunately, it still works with no shorts or hum.
Do you have this radio?
Regards and many thanks for your kind help,
Donald
