siemens: K32GWB;
This article refers to the model: Luftwaffen-Koffer K32GWB (Siemens (& Halske, -Schuckert Werke SSW, Electrogeräte); Berlin, München)
? siemens: K32GWB;
01.Feb.15 20:20
35
Does anyone have a dial string diagram for the K32?
String position from service picture
02.Feb.15 11:22
35 de 2345
John,
unfortunately, the service manual gives no string diagram. However, if you look closer to the picture given in the service manual, it can be seen how the string should be.
This picture may be down loaded in normal size, and you will find it beneath the schematics.
Regards,
Dietmar
K32 help
11.Feb.15 00:26
156 de 2345
Did you get your dial string problem fixed? I have a K32. Maybe I can help.
Regards,
Donald
K32 string solved
11.Feb.15 15:41
191 de 2345
Thanks, we finally figured it out.
