siemens: K32GWB; Wishing to reconnect loose wire for UY11 tube
? siemens: K32GWB; Wishing to reconnect loose wire for UY11 tube
While removing my K32 from its case, a wire has come loose from its connection. It is a brown wire that you can see in the attached photo. I cannot determine where on the UY11 this brown wire attaches. It goes back into the radio into a wire bundle that I do not wish to disturb. Can you assist me, in determining where this wire connects?
Grammophon
Dear Samuel,
I am having a NORA chassis wich is the forerunner of SIEMENS K32.
At the place shown on your pictures a sreened cable is leading to a coupling of wich I believe, it´s a grammophon coupling. The screen is going to the center, the inside cable to one of the round jacks.
At your chassis there should be another single cable, violet or blue, coming through a hole just beside the big one and leading to the 2nd jack.
Regards
Reiner
Hi again,
I just discovered, you are not talking about the thick brown cable but the smaller one marked by a red lasso and arrow. However the answer remains the same. :-)
Reiner
Thank You!
Hello Reiner,
Thank you very much for the information. Of course, as soon as I read your reply, I remembered seeing the wire go the gramaphone connection in the past!
Best Regards,
Sam Baker
