dongguan-x: Sihuadon R-108 - 2020 version: Technical observations
06.Nov.21 16:32
3849
Jose Mesquita (P)
Articles: 111
Count of Thanks: 10
Jose Mesquita
Having acquired the Sihuadon R-108 version 2020 of the original Radiwow from 2018, I have dismantled it to check the hardware setup. This is what I could find so far. Updates and corrections are welcome.
The radio uses two main PCBs and two small socket holder PCBs.
The small PCBs are used to hold the Antenna and Earphones sockets.
The main PCBs are:
  • The MAIN BOARD - Installed at the back cover, contains the Power Supply and the Analog/Digital Receiver sections.
    • My unit came with the "R-108 DSP V06 MAIN BOARD 2019-03-18" assembly.
    • Older Radiwow units may show other versions, like this one: "R-108 DSP V03 MAIN BOARD 2016-11-08"
  • The KEY BOARD  - Installed at the front cover, contains the Digital Management and Display sections.
    • My unit came with the "R-108 DSP V04 KEY BOARD 2018-11-30" assembly.
  • The two assemblies are joined in piggyback configuration using one single interconnect (JP1 male on the KEY BOARD PCB, JP2 female on the MAIN BOARD PCB).
"R-108 DSP V06 MAIN BOARD 2019-03-18" PCB main components
IC1 Si4734D60GU Silicon labs DSP Radio Receiver
IC2 65K5 1.8V LDO Regulator
IC3 6209A MicrOne LDO Regulator
IC4 Unidentified Charger, near MicroUSB, hidden by a capacitor
IC5 CS8575S 2-Channel Audio Power Amplifier
IC6 CD7358GS FM Front End for Air Band (at the underside of PCB)
IC7 FS8308 PLL Frequency Synthesizer for Air Band
X2 35.328 XTAL Crystal for Air band synthesizer
X3 Unidentified XTAL Crystal for SiLabs Si4734D60GU
"R-108 DSP V04 KEY BOARD 2018-11-30" PCB maain components
U1 Unmarked MCU and LCD Display driver, under epoxy blob, 80 pin SMD
IC8 24C08BN 8 KByte Serial EEPROM
X1 Unidentified XTAL Crystal for MCU
Brief technical details (to be detailed at a later time)
In order to be able to offer Air Band on these R-108 models, XHDATA added dedicated chips for that RF band, where the SiLabs DSP Receiver chip covers the LW/MW/FM/SW bands. As a consequence, while soft muting is observed on the DSP covered bands, the Air band behaves like any other analog receiver with no soft muting at all.
