sobell: Sobell 515 still struggling
This article refers to the model: 515P (Sobell Ind., Slough)
? sobell: Sobell 515 still struggling
26.Jan.19 19:08
238
David MacFarlane (GB)
Articles: 4
Count of Thanks: 22
Still not terribly sure if I am doing this the right way according to forum rules, but I got the chance to spend some time with my Sobell 515P, and all of the data sheets I can find indicate that V2 is an EAF42. On my set V2 is an EF89.
This is an 8 pin base, and pulling up the comparison, I find the whole pin out to be different, and the original diagram shows L13 to be mounted on the back of the chassis.
I am wondering if there has been a lot of surgery on this model long ago (for none of it looks disturbed), or if indeed, it is a different circuit which has been employed, perhaps in order to allow the EF89 rather than the original EAF42.
The characteristics are similar, but not identical, and pin 6 is certainly not the grid on the EF89.
Any hints please?
29.Jan.19 09:46
238 from 2429
Rolf Beckers (D)
Articles: 230
Count of Thanks: 20
Rolf Beckers
Dear David,
It's quite normal that in the early fifties (e.g. 1952 to 1955) the tubes were changed from the 40-series (Rimlock) to the 80-series tubes (Noval).This happens at many other ratios from that period too. Smaller manufactures did this without changing their service documentation.
Regards
Rolf Beckers
29.Jan.19 13:22
276 from 2429
Articles: 4
Count of Thanks: 12
Thank you again Rolf, now its making sense - I just found I had to go and do lots of homework with pin outs and grids, and I am getting closer to my teenage level of competency (1963), all the old data is coming back slowly from the memory banks as I renew a once keen hobby - that's the trouble with careers, they can carry you off on a huge tangent from where you intended to go, and one finally ends up in management - nothing like one's original intent.
I'm getting there, from Biasing my Marshall amp's output pairs to re - aligning the IF on this Sobell - strange sort of pleasure feeling, doing what you want!
Wonderful site and forum - thanks again.
Dave.
