sokol: RP204 (RP 204);
04.Jul.06 20:25
Colin Boggis (GB)
Articles: 12
Count of Thanks: 14
I recently had a SOKOL RP204 in for repair - the oscillator mixer transistor had failed. Not having any Russian devices I ascertained that TR1 was Silicon PNP type & function RF. I fitted a BF423. Radio did not function - voltage readings showed that current through BF423 was too high. I added 10,000 ohms from base to ground to correct the bias. Radio then functioned perfectly. I have added a simplified circuit for this stage of the circuit in .jpg format to assist in servicing this first stage of the radio. Attachments:
05.Jul.06 00:22
Howard Craven (GB)
Articles: 95
Count of Thanks: 22
Hello Colin,
That's very good !  I have ordered a load of Russian Germanium transistors from a collector in Russia so should you ever need an original transistor for a Soviet radio I might be able to help.
Howard.
Sokol RP-204
28.Sep.11 23:35
541 von 4147
Didier Tholomier (F)
Count of Thanks: 10
Hello Howard,
if you still have the RP-204, could you scan the schematic from the original paper, and upload it to Radiomuseum ?
as I can see it on your picture.
Best Regards.
Didier THOLOMIER
