sony: ICF-SW100 (ICFSW100); typical failure
This article refers to the model: ICF-SW100 (Sony Corporation; Tokyo)
25.Aug.08 12:47
7839
Martin Bösch (CH)
Articles: 612
Count of Thanks: 24
Martin Bösch
Early production samples of this radio tend to fail, a copper ribbon cable connecting the lower and the upper part of the radio will be bent repetitively over a very sharp edge of the lid. After a while, the copper ribbon cable connections are likely to break, some of the keys will become inoperational, sometimes this will happen even to the on/off - button. Rarely the signal ribbon cable will brake.
You might recognize the early ICF-SW100 sets by the copper connector, that can bee seen in the gap, in later models produced after autumn 1997, You see a black plastic cover over the connector and the lid mould has been changed.
You might try to repair Your set using a file to dull the sharp plastic edges where the connector will have to get past. There has been a Sony repair kit for these early models with a different lid mould.
Find more informations on this site of Michael Rathbun.
Hope this helps
Martin Boesch
