telefunken: 876WK (T876WK); Gross-Super - schematic differences
? telefunken: 876WK (T876WK); Gross-Super - schematic differences
31.Jul.11 20:43
119
Robert Sarbell † 22.3.22 (USA)
Articles: 358
Count of Thanks: 4
Gentlemen,
Like Mr Carabas,
I am also beginning the alignment procedures on the early 1937/1938 Telefunken receivers; however, I am somewhat still curious to explain some minor circuit changes (or improvements).
In my model T776WK, the mixer-oscillator tube ACH1 does not reflect the addition of the small 250pF capacitor which bridges the kathode and the filament pins???
Then in the output stage, from the audio pre-amp in the AM2 tuning eye to the control grid, there is the identical coupling capacitor and the 0.5M ohm resistor phowever, the 776WK places a final 100 ohm resistor entering the grid. . . . . . .while in the 876WK the circuitry the corresponding resistor is rated for 1K ohms.
Are these 2 small parts significant enough to render the receiver "muted" if not precisely followed?
One last question - although I have had the radio for some time, I was not able to locate dropping resistor R43. If the previous owner (or technician) removed the item and did not replace it; could the item have been mounts somewhere on the loudspeaker assembly??
Respectfully,
Robert
I would also like to express my sincere Appreciation and Thanks to member Mr Hugo Sneyers for the replacement of the complete BF2 cylinder - without which the Telefunken Gross-Super could not be "restored". . . . . . . . . .
NOTE: I have prepared what I believe to be a complete "TFK 776WK Alignments" procedural checklist (in English) if one of the radio engineers would be kind enough to review my efforts. I have not yet "folded in" the Illustrations, but I have included a brief description of the needed graphics. I have also included the use of my recently acquired Rohde & Schwarz BN4114 Signal Generator as one of the principal test equipment items.
Tfk 876WK / 776WK
03.Aug.11 12:13
119 de 2925
Johann Leber (D)
Articles: 130
Count of Thanks: 4
Hi Robert.
 1)In Model Tfk 876WK the 250pF bridges the filament to ground, Katode is grounded directly
 2) the two smal Parts 100 ohm/ 1 k should prevent the AL4 from VHF generating. The value isn,t so important. Usualy it is 50 Ohm to 1k.
3) Resistors R43/44/45 divide the Ug2 for the ACH1/ AF3 aprox. 80 Volts. R45 in the same way reduces the voltage by aprox. 5 Volts.They are adjustable at the Chassis backside, for strong Stations. You find all these Items on the innerchassis.
4) I would like review your english Aligment, please send them by email. Regards J. Leber
TFK 876WK/ 776WK - Variations
03.Aug.11 16:11
140 de 2925
Articles: 358
Count of Thanks: 4
Hello Johann,
Thank you so much for the information - the main reason I was asking is because the original illustrations depicted the R43 dropping resistor connecting from AF3 pin7 over to the AL4 pin 7 and it seemed to be "out  of place". I realize that frequently some tube pins are used strictly for connecting points. . . . . . . .
I have also prepared the accompanying "setup" procedures which were produced by Telefunken to assist in the correct alignment steps for these peculiar radios.
I will send both files (via email) for your review  - and also add the comment that some other German members have had some "challenges" as recently as January 2010 while attempting to align the specific TFK 776WK - because of the peculiar front end.
Respectfully,
Robert
