toshiba: toshiba Model GP-33F
? toshiba: toshiba Model GP-33F
27.Dec.20 23:12
44
Charles Chubak (USA)
Articles: 9
Count of Thanks: 3
Hi all,
Can you help me with a weak left channel? Same low volume when I try both speakers on left channel.
Thanks,
Charlie
28.Dec.20 11:46
44 from 820
Marc Gianella (CH)
Articles: 304
Count of Thanks: 3
Hi Charlie
You are referring to the model GP-33F, which has at least another assembly of the push-pull stage.
Please create a new model here in RMorg and ask for the schematic.
-> Edit: No need to create another model, it is here
This thread should be moved.
Moreover, pictures of your model would be appreciated ;-)
If the right channel works you may do comparative measurements at the pins of the final stage transistors. Be careful, the germanium transistors are easily destroyed. Always refer to ground and avoid shorts.
But first try to bridge the output capacitor with a known good one.
Kind regards
Marc
