UKW alignment
UKW alignment
I found my 9E91 in very nice conditions, the only think is that the UKW isn't working.
I tried several tims to realign this band without results, also changing some tubes.
Sometimes seems you can find some signsls, but then after a while everything is missing leaving the radio like dead on this band.
Someone can help about?
Many Thanks
G.Verrini
What set are you dealing with ?
Dear Gilberto,
are you dealing with this radio set here: http://www.radiomuseum.org/dsp_modell.cfm?model_id=16690 ? This would be an advantage since it´s the only one with schematics available.
Cheers
Yes, it's this Stern Radio 9E91
Yes, the set is this.
I have the schematic, it's on the back panel of the radio, but isn't helping me.
I tried to align from the last section (discriminator) going back, but wasn't solving.
Many Thanks
Schematics
Dear Gilberto
I was somehow confused - there are no schematics available !
Could you scan the one from the back panel. If you sent it to me via eMail I possibly could add it to the model page. You can find my eMail adress here: www.hans-kamann.de
Cheers
Scanned schematics
I'll try to do it, the problem is my scanner isn't working.
As soon I'll find one or go to a friend with, I'll send you a copy.
Ciao
