unidentified multimeter
? unidentified multimeter
20.Sep.10 14:52
151
Jan Terranea (NL)
Articles: 63
Count of Thanks: 15
Jan Terranea
Hoping that someone will recognize my mystery 11,5 kg multimeter, I attach a photograph.
It looks like Philips.........
Thanks in advance for your help to solve the mystery.
Jan Terranea.
Unknown Philips Multimeter
28.Sep.10 10:07
151 from 2681
Officer
Articles: 5751
Count of Thanks: 17
Dear Jan
Please create a new model page for Philips NL.
Name:
Multimeter
In the text you can write that you have not found any trace of a model name but believe it is a Philips.
Then it would be good to load up also a picture frontal, so that the scale is well visible - and one of the back side.
I hope you can zoom a little bit (stand further away from the object) for not getting those "falling lines" and you could stand a little bit on the side so a body is seen, not only the front and (too much) of the top.
Good luck!
Now the multimeter is shown, thanks
11.Oct.10 18:41
220 from 2681
Officer
Articles: 5751
Count of Thanks: 15
Dear Jan
Thank you for proposing the model and loading up the nice pictures.
Now there is more hope that somebody can identify the model.
Normally you should answer in the thread that you have done the job - otherwise one has to check several times. I did now join your thread to the model. It will stick there.
