Tube Philips 505 Cine Sonor (.33.)
27.Mar.10 18:48
25
Georges Van Campenhout † 28.4.22 (B)
Articles: 202
Count of Thanks: 23
Dear Radio friends,
I recently received a Philips Tube, model 505.
On top of this tube is written (see pictures)
PHILIPS
CINE SONOR
505
(.33.)
Inside, one can clearly distinguish two diode systems!
I wonder if this is the same tube??
only 3 pins = half-wave rectifier
27.Mar.10 21:24
25 de 6797
Articles: 1801
Count of Thanks: 23
Hello Georges,
since this tube has merely 3 pins, it can't be anything else then a half-wave rectifier, although two diode systems are visible. It's very likely that you can find a parallel connection inside the tube. I have very little doubt about the correct designation 505.
This method was even used in some other cases: have a look at the second picture of the rectifier type 1803 (under “more”) - and you can see a 1803 which is made in the same way. The connection between the two anodes is clearly visible.
Best Regards, Jacob
Rectfier tube Philips 505
28.Mar.10 11:04
70 de 6797
Articles: 202
Count of Thanks: 23
Thank you, Jacob.
Indeed, looking carefully into the glass base shows that the two heaters are connected in series.
But what about the other marking: CINE SONOR?
Was this rectifier used only for cinema applications? Or is there another explanation?
Best regards
Georges
Cine Sonor
28.Mar.10 15:16
97 de 6797
Georg Richter (D)
Articles: 909
Count of Thanks: 18
Georg Richter
Philips Eindhoven had a "Cine Sonor" department for cinema equipment production (like Siemens had a separate company "Klangfilm").
It may be that Philips tubes which are labeled "Cine Sonor" was sold for a higher price for "dedicated application", similar to the "Klangfilm" tubes which was (often) standard tubes with a different numbering system to prevent cinema operators to use cheaper tubes for replacement. As far as I know the cinema operators had to sign a contract with the cinema equipment supplier.
I do not know if those "cinema" tubes has had a higher reliability or was selected for reaching the upper limits of the specifications.
If somebody can quote a contract between cinema equipment manufacturers and cinema operators, or can provide data sheets or an advertisement folder of Philips "Cine Sonor" equipment we will know more.
Best Regards
GR
