506 and 506K tubes
506 and 506K tubes
![Jean-Pierre Waymel](https://www.radiomuseum.org/image.cfm?image=f_waymel_jeanpierre_2002_1.jpg&width=120&height=140)
Hello,
Information about the differences between a 506 and a 506K.
I think that there are also two different sizes (height) but I don't know if there is any correlation between the size and the letter K.
It's important for instance in the Philips 2514 model which needs the smaller (height) tube !
I also sent this info to the Tube page (Typical circuit).
Cordially.
Jean-Pierre.
K = short
![Wolfgang Holtmann](https://www.radiomuseum.org/image.cfm?image=nl_wolfgang_holtmann_2003.jpg&width=120&height=140)
Hello Jean-Pierre
The letter K stands for "kort" in the Dutch language, which means short.
The right hand drawing of a "typical application" for the 506K is not correct!
As you can see on the tube pictures, all of them are directly heated! No additional cathode present.
Kind regards.
