6AH5 (6AH5)
6AH5 (6AH5)
25.Apr.12 23:50
28
Michael Watterson (IRL)
Articles: 1144
Count of Thanks: 24
There is [ seemed to be] also a Raytheon B7G 6AH5 which no doubt is totally unrelated. It might be an RF/IF Pentode
[EDIT]
Examing very carefully under a bright magnifiying lamp confirms I'm wrong on my first assumption. There is a very slight curve on the top of the "5" if must be a "6" with the exact critical part of the loop missing!
Probably a 6AH6
26.Apr.12 07:39
28 von 4179
Emilio Ciardiello (I)
Articles: 527
Count of Thanks: 12
Emilio Ciardiello
Michael,
according to the RMA register, the 6AH5G is an octal tube assigned to Philco in January 1942. Sibley also gives a metal variant, as 6AH5. The closest B7G Raytheon tube could be the 6AH6, a sharp cut-off pentode. Maybe that the last digit is partially rubbed out on your sample.
Emilio
Off-standard pin assignment
26.Apr.12 09:41
48 von 4179
Articles: 1801
Count of Thanks: 18
The pin assignment of this tube differs much from the standard. If there really is a metal variant, to which pin will be the shell connected to ?
If someone has the idea to replace tentatively this tube by a metal 6L6, it will have unpleasant consequences.
