6E5 (6E5)
? 6E5 (6E5)
11.Nov.11 00:17
36
Alessio Castagnini (I)
Articles: 21
Count of Thanks: 15
Alessio Castagnini
Hello, is possible change a 6E5 with a 6E5C ?
Please, let me know!
Thanks a lot!
Bye
Octal base
11.Nov.11 10:32
36 from 4857
Michael Watterson (IRL)
Articles: 1095
Count of Thanks: 9
The normal 6E5 is 6 pin base and "bulb" shape.
The 6E5C is straight sided and octal base.
So if you change the tube socket or there is space for an octal to 6 pin adaptor (by moving the existing base which usually isn't on the chassis), then yes it should work. The pattern is the same and the sensitivity should be similar.
