6F7M (6F7M)
6F7M (6F7M)
28.Dec.11 22:55
17
Frank Van de Ven (CDN)
Articles: 5
Count of Thanks: 10
 All the Rogers tubes with the "M" suffix, have an Octal shell base, with 8 contact pins and 1 dowel locator pin. The Museum informations states 7 pins. The M series are all Metal Spray Shielded with contact to pin 1, which serves to ground the metal shell.
There is also not a direct substitute for this tube/valve. A 6P7G may be used if the socket is rewired.
Please see this PDF file for M series Rogers tubes.
http://pacifictv.ca/schematics/rogerstubedata.pdf
Regards,
Frank van de Ven
Done
29.Dec.11 07:14
17 from 3413
Emilio Ciardiello (I)
Articles: 527
Count of Thanks: 10
Emilio Ciardiello
Dear Frank,
Many thanks for the information you sent. The tube base type is now changed to octal. If you have even a pinout diagram to load it would be fine.
Emilio
