Astor radio
? Astor radio
Dear Radiophiles,
From a friend,who is also a member, I got one Astror radio,similar to model FP which picture I send atatched but which originaly has been built for battery operation.Unfortunately it came without tubes and without the original wiring or any identification plate,,thus making impossible for us to identify the model number.Both of us would like,if possible,to have the schematic of this battery version of this FP model,so that it could be reconstructed.Is there anyone who could give us a hand both to identify this model,the caractheristics and possibly the schematic?Thanks in advance, A.B.Regada
Astor
         Hi Antonio
Can you post a picture? It could be a model LJ using the following tubes:
1T4, 1R5, 1T4, 1S5, 3V4
Astor stamped the model numbers into the back of the chassis.
Peter
Astor Radio
Hello Peter,
Thank you for your answer.Here I am atatching the picture of the radio that I have,which is very similar to model FP.Hope that you can give me more details.Best regards,A.B.Regada
Attachments:- Unknown battery Astor (132 KB)
astor pic
         Sorry, Antonio
I don't see the pic appears as 0kb and gives me an error
Peter
Astor unknown model
Hello Peter,
There has been some oversight on this side,let us see if I can upload finally my picture.Best regards,A.B.Regada
Attachments:- as minhas imagens ,radio ASTOR 004 (132 KB)
Pictures ?
         Pictures with 0 KB.
               Nobody can see what is behind.
               The moderators or administrators are required ;-)
Arpad Roth
Astor radio
Hello Mr.Roth,
I already realized that for some reason that I don´t know,my pics didn´t reach the destination,although on my side everything seemed to be ok.Anyway I have been able to get the information that I needed.Best regards,A.B.Regada
? Wrong file name
         "Some reason(s)" for dead (0kB) file links are caused by using forbidden characters in file names.
In this case are "space" characters between "radio", "Astor" and "004":
target="_blank">radio ASTOR 004.jpg<
Allowed characters are
a - z, A - Z, 0 - 9, dash and underscore, and nothing else.
Please realize that RMorg is not running a Windoze file system (which is unfortunately tolerant for silly charcters).
The original question keeps open, but some posts (#4 to #8) are obsolete after uploading the picture with correct file name in post #3
Best Regards,
GR
Upload picture
           This is my attempt to publish this picture yet.
           As moderator, I can open the image in the article by Mr. Hugh's in edit mode.
           But I can not re-insert in the article by Mr. Hugh.
It is possible that it is this model ==> Astor GP413
           Regards WB.
- Astor Radio (25 KB)
- Astor Radio Bild gross (132 KB)
Astor Radio
Dear Sirs,
Thanks a lot for your explanations.My Astor radio has been easily identified by Peter Hughs: it is model MK, MW only and uses valves 1C7G 1M5G 1K7G 1L5G,all octal,2 volts heater.The set is now beeing recovered to its original shape.In due time will be uploaded as new model.A.B.Regada
? Astot Radio
           Will this model be applied?
           This is how this post makes no sense.
           A similar device in the AC version is the Astor Model FP.
           Regards WB.
This thread was moved automatically.
Astor MK
Post moved to the model.
