becker: Speaker Impedance for 1952 Becker Solitude 3
? becker: Speaker Impedance for 1952 Becker Solitude 3
11.Aug.10 01:16
32
Francis Seidl (USA)
Count of Thanks: 13
Weiß jemand den passenden Lautsprecher Impedanz für Becker Solitude 3?  Does anyone know the correct speaker impedance for the Becker Solitude 3?  Thank You!
Speaker impedance
11.Aug.10 13:14
32 de 2801
Officer
Articles: 1683
Count of Thanks: 7
Dear Francis,
the Becker Solitude 3 needs a low impedance speaker.
The schematic shows a tapped output transformer, the lower secondary winding requires 2.5 Ohms as a correct speaker load. This connection ends at the screw terminals. You may use two speakers (each 4...5 Ohms) in parallel to ensure proper working.
If only one loudspeaker (4...5 Ohms) is used, the speaker connection at the output transformer should be changed from the center tap to the (unused) high tap.
Bernhard
