blaupunkt: 4431; Arkansas
? blaupunkt: 4431; Arkansas
11.Feb.09 23:28
David Schulman (USA)
Articles: 18
Count of Thanks: 9
David Schulman
Hopefully, I have a simple question... Does anyone know how the chassis is removed from this unit? From the front or the back? I don't want to tear things up too bad if there is an easy way to do it. Thanks for your suggestions. David
remove chassis
13.Feb.09 01:15
Hilmer Grunert (D)
Articles: 386
Count of Thanks: 12
Hilmer Grunert
Hello Mr. Schulman,
The chassis is to remove from backside. Screws are turning at front side over the turntable. Note: the rubbers between chassis and wood are most adhesive. You must lever them softly with a Screw driver.
Greetings
Hilmer Grunert
Thank you
15.Feb.09 18:17
Articles: 18
Count of Thanks: 10
David Schulman
Thank you so much for the information. Removed the chassis without any problems.
David
