channel: Channel Master Bring-Along 8
Count of Thanks: 13
Hallo, I've some important informations about this tv set. I've another piece of it (very rare), and I found schematic in my library. I finally discoverd that this is a Sanyo model (made in japan), sold in USA under the Channel Master commercial mark. As a Sanyo set, it's model numer is "8p2". So, if we merge the infomations about these two model number (of the same object) , "Channel Master Bring-Along 8" and "Sanyo 8p2", we could optimize search results. It also appears (thanks to some ads) that the year is 1961.
Better to cross link both in the notes rather than "merging". That is to list the other maker & model and make that a link.
Very common to have the same model with two badges and apparently different makers.
