grundig: Connector type
? grundig: Connector type
12.Feb.25 01:03
39
Dave Oneill (USA)
Articles: 75
Count of Thanks: 11
What type connector does this use? I tried a pl-259 and it
Does not work.
12.Feb.25 09:20
39 von 6316
Torbjörn Forsman (S)
Articles: 219
Count of Thanks: 3
It might be a non-standard "metric" PL-259 connector, using a M16 fine thread instead of the standardized UNEF 5/8-24 thread. I have encountered those metric connectors on some old italian and japanese equipment.
12.Feb.25 12:12
70 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 8
grundig tv-1: Connector type
12.Feb.25 14:18
92 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 13
Can someone translate the german manual on this site so that I know which terminals do what on the meter. I believe the outer 2 banana ports are for a/c voltage and the center one for RF. Thanks
13.Feb.25 10:17
172 von 6316
Daniel Consales (D)
Articles: 247
Count of Thanks: 6
Daniel Consales
Hello Mr. Oneill,
I own a Grundig RV11 which has similar connectors. I'm astonished the PL-plug didn't fit - mine does.
Also the description of the TV1 shows "international used rf-connector" which is the PL-259 ...
The manual of the TV1 states that one can use cables with banana plugs (gnd is the right socket (7) ).
Kind regards,
D. Consales
P.S.: when I look at your plug - that seems not to be PL-259 at all
13.Feb.25 17:26
209 von 6316
Michael Watterson (IRL)
Articles: 1144
Count of Thanks: 4
Your PL529 looks like a cheap crimp one. regular ones don't have the tip. I have had cheap PL529 connectors with a poor thread.
13.Feb.25 21:02
232 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 7
Thanks for the help guys. I have a more serious problem. I connected the
Outer probes to a/c and it sparked like an arc welder. Neither side of the
Plug goes to the chassis. What is causing this? Maybe the ports are wrong, i cant read
The german instructions.
13.Feb.25 21:41
238 von 6316
Daniel Consales (D)
Articles: 247
Count of Thanks: 5
Daniel Consales
These are both ground (there is a mistake in the description, 8 + 9 is the output, but 8 is the gnd, not 9)
Your input should be fed to the center of the coax socket (4mm banana plug) and gnd (7 or 8).
14.Feb.25 00:09
258 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 6
I put a/c voltage to 8 and the center coax, nothing.
14.Feb.25 01:22
262 von 6316
Daniel Consales (D)
Articles: 247
Count of Thanks: 6
Daniel Consales
Normal operation is in position "300ms" ...
- first before switching on adjust the meter to zero position
- now switch on without any connection to the input. Toggle between "Eichen/cal. V" and "300ms". The reading should be the same in both positions. If it's not you can calibrate that with the screw in the center of the device (4).
- now you can switch to "300ms" and connect your voltage to 6(coax center) + 7
If that does not work you'll have to find the error in the device ...
P.S.: device should be 10 minutes on before calibration
14.Feb.25 01:55
266 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 4
Still does nothing. This is an ac meter, right. Probably needs
To be recapped. Its 65 years old. Meter has lots of caps.
14.Feb.25 02:58
270 von 6316
Daniel Consales (D)
Articles: 247
Count of Thanks: 5
Daniel Consales
You can try - but I wouldn't without a good reason. There are many voltages in the circuit diagram you could check first and go from there. Even a tube can be bad so changing all caps imho does not make much sense before that. Sometimes it works - but what if not?
14.Feb.25 07:35
290 von 6316
Articles: 1144
Count of Thanks: 5
That looks like a polyester cap beside the Electrolytic. They are likelyu OK. Only non-hermetic paper capacitors need replaced wholesale.
The metal can electrolytic caps usually reform if the rubber end hasn't cracked and allowed it to dry out.
14.Feb.25 12:56
327 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 5
I will check the voltages per the schematic but.....it states on the bottom of the schematic  voltages are with 200v. I am using 120v usa. Is that an issue?
14.Feb.25 13:07
331 von 6316
Articles: 1144
Count of Thanks: 8
Unless there is a setting for 115V, you'll need a transformer to 220V.
However the model page writes that it also supports 120V.  I also can see the mains transformer has a 120V tap on the input.
Possibly the mains fuse is positioned for 120V or 220V input as I see two fuse holder at the mains cable.
Then the circuit diagram voltages are the same as for 220V mains.
14.Feb.25 13:37
335 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 4
Thanks Michael for that input. Daniel, you said that normal operation is 300ms but but looking
at the schematic 300ms comes off the 6.3v transformer and goes no where. 30ms go to the meter. Any thoughts?
 17
14.Feb.25 20:59
398 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 4
I tested the ECF80 tube and the pentode is bad. The site says this tube is the same as a 6BL8 but my hickok tester has different settings for these and the 6Bl8 settings do not work. Same with the EF85, its not the same as the 6CF8. The settings for the 6CF8 do not work for the EF85. If the ECF80 pentode is bad can the meter not function?
 18
15.Feb.25 02:09
429 von 6316
Daniel Consales (D)
Articles: 247
Count of Thanks: 5
Daniel Consales
Your fotos show the fuse in position 120V - so the readings have to be the same.
Regarding the 300ms: that's what the description says :-)
 19
15.Feb.25 02:39
434 von 6316
Daniel Consales (D)
Articles: 247
Count of Thanks: 10
Daniel Consales
The ac from 6,3V goes there AND to the voltage devider for the calibration process.  The result has to be the same in both positions. So the amplifier has to be adjusted so that the loss through the devider gets compensated which leads to the same reading like before. Hope that is understandable (?)
 20
15.Feb.25 09:28
458 von 6316
Articles: 1144
Count of Thanks: 5
ECF80 and 6BL8 are interchangeable. The Hickok testers are mostly good/fail testers for new tubes and not so very useful. Also compare the Hickock settings with actual pin data.
The 6CF8 is an EF86. And EF86 and EF85 are not interchangeable.
An EF85 is interchangeable with a 6BY7
  EDIT Maybe you typed EF85 by mistake? The Grundig meter does use an EF86
 21
15.Feb.25 09:46
464 von 6316
Articles: 1144
Count of Thanks: 6
I would replace the selenium rectifier with a silicon bridge or 4 x 1N4007. Maybe put 100 Ohms 2.5W in series with either input or + out (which ever is easiest) if HT is too high.
Even if it's working now it will fail.
Check the HT voltages first, then if OK: cathode voltages and anode voltages.
IF HT voltages are all OK
The Cathode voltages being 50% low means the tube is low emission. I'd not worry if 25% low. No cathode voltage means the tube is dead, or socket is faulty as there is no negative supply.
 22
15.Feb.25 09:50
467 von 6316
Articles: 1144
Count of Thanks: 4
C32 0.1uF on EF86 anode should be examined. Replace if a paper type. The moulded pale mustard capacitors are plastic film and should be fine.
 23
15.Feb.25 13:35
491 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 17
Yes typo, should be ef86 and its different then the 6cf8. Hickok is the
Best tester available.
 24
15.Feb.25 14:12
494 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 4
Now i know why americans say stay away from german stuff,
Its a pain to work on. Dont see the selenium rectifier. Hidden
Electrolytics probably are bad. Resistor unknown value
Looks burned. Bulb (good) does not come on, no voltage
But transformer puts out 6.3v. This meter holds a charge
For a long time and shocks.
 25
15.Feb.25 14:36
501 von 6316
Daniel Consales (D)
Articles: 247
Count of Thanks: 5
Daniel Consales
Looks like the rectifier is right before your eyes - above the burned resistor you showed ;-)
The resistor starts with blue/grey so "68?" so it will be R27 - so no wonder nothing works, the tubes dont get anode voltages.
I can understand your frustration but in my experiences  maintanance on _every_ measuring instrument is a pita regardless of the vendor
P.S.: and it holds the voltage because the failure of the resistor ...
 26
15.Feb.25 14:51
509 von 6316
Articles: 1144
Count of Thanks: 6
Hickock is a basic go/fail shop tester.
See the Avo VCM163 or even the VCM Mk IV (which some Belfast retail TV & Radio shops still had in 1966+).
I've used and restored all three models.
There is no problem with old Grundig or German stuff 1950s to 1970s, it's just not what you are used to.
Take out the tubes and the selenium bridge Likely about 1.25" square 1/4" thick aluminium "wafer" with 4 terminals bolted to chassis. Then feed the HT rail from a 30V DC PSU current limited to about 10mA. This will reform the electrolytics. Any Electrolytics where the current doesn't fall to less than 1mA or that are open circuit after 4 hours are faulty.
I've also restored Grundig radios and tape. Multiple USA RCA and Hallicrafters radios.
 27
15.Feb.25 17:57
527 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 8
Why did they use huge capacitors in parallel to get 100uf. There are 3
Of them.
 28
15.Feb.25 18:03
529 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 5
The power chord has 3 connectors that go to the board. Red is cut
Off at the power plug.
 29
15.Feb.25 23:29
572 von 6316
Articles: 219
Count of Thanks: 2
Regarding the electrolytic capacitors, its possible that the designers chose to use that type of capacitors because it was cheap and used in large numbers in mass produced radios etc. Maybe a reason for distributing the capacitance in several cans was to increase life of the capacitors by sharing the ripple current between them.
Regarding the mains cord, the colors according to german standards from that time are as follows:
Black - phase
White or light grey - neutral
Red - protective ground
It is common - but dangerous - that the ground wire is cut in measuring instruments, if some user has had problems with hum due to ground loops or wanted to make measurements in AC/DC sets or televisions with "hot" chassis, without using a proper isolation transformer.
 30
19.Feb.25 22:36
801 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 8
I was thinking of putting a 3 prong ac plug on the power
Cord but i noticed the schematic does not show one.
 31
24.Feb.25 22:19
1148 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 5
 32
06.Mar.25 01:16
1548 von 6316
Dave Oneill (USA)
Articles: 75
Count of Thanks: 5
Replaced the caps and diodes and meter still doesnt work right.
There was a crack in the circuit board preventing the filament
Voltage but now the meter pegs full right. Calibration does
Nothing. Any ideas?
