braun: Dial lamp
? braun: Dial lamp
18.Apr.17 14:40
72
Meyer Rochwerger (BR)
Articles: 122
Count of Thanks: 13
Meyer Rochwerger
Dear friends,
The service manual indicates the use of two bulbs with part number T1000 089z.
Someone knows where to buy these items. Or the manufactureer / code?
Thanks in advance,
Meyer
braun: Dial lamp
19.Apr.17 09:43
72 de 4230
Articles: 2327
Count of Thanks: 9
How does the lamp look like?
The bulbs have 1.2 volts 0.2 ampere.
These lamps with screw thread
E10 are available.
Regards WB.
braun: Dial lamp
20.Apr.17 23:46
149 de 4230
Articles: 122
Count of Thanks: 22
Meyer Rochwerger
Hi Wolfgang,
It's a tiny unusual type.
Take a look...
Cheers, Meyer
braun: Dial lamp
21.Apr.17 10:20
175 de 4230
Articles: 2327
Count of Thanks: 15
You can take these bulbs ==> Varta 703.
These must be soldered into the socket of the defective bulbs, which will not be difficult.
The larger current does not matter.
Regards WB.
braun: Dial lamp
21.Apr.17 13:37
186 de 4230
Articles: 122
Count of Thanks: 6
Meyer Rochwerger
I think in this case the current should be below 100mA.
I found one on Radio Shack with the specifications 12v / 60mA (the power supply provides 12v)
But I'd like to find the right type that fits into the original receptacle without soldering.
As a last option I'm going to disassemble the panel and solder the bulbs. It's going to be a lot of work. Whoever worked with this radio knows what I'm talking about.
Meyer
braun: Dial lamp
21.Apr.17 14:56
192 de 4230
Heinrich Stummer (A)
Articles: 252
Count of Thanks: 11
Heinrich Stummer
Hello,
the lamp shown in your photos (#3)  looks like a  "BA7s"  type.   Look here.
Best regards
H.Stummer
braun: Dial lamp
21.Apr.17 18:55
208 de 4230
Articles: 2327
Count of Thanks: 16
Be careful, the lamp must be 1,2 (one/dot/two)Volt, not 12(twelve)Volt.
