DU4 (DU4)
This article refers to the component: To the tube/semiconductor
DU4 (DU4)
03.Mar.10 03:15
20
Hello All,
I notice that the photos for this tube are misplaced. The DU4 is a rectifier made by Mullard and I believe is the equivalent of the Philips 506. The photos show a De Forest tube, probably a triode.
Regards,
Stuart
Probably a DeForest DV4
03.Mar.10 09:17
20 from 3514
Dear Stuart
How right you are! Thank you. DeForest made a couple of DV tubes and I can imagine that the V was read as an U. I moved the pictures to the DV4. I hope the DV4 is really a triode. I could not find any evidence about the DV4.
Now we miss a photo for the DU4 ... which is supposed to be a 505 (not 506).
