dynaco: FM-3; Dynatuner
This article refers to the model: Dynatuner FM-3 (Dyna Co. (Dynaco); Philadelphia PA)
? dynaco: FM-3; Dynatuner
24.Jun.12 17:34
42
Antonio Fabio Colorito (I)
Articles: 3
Count of Thanks: 17
Hello everyone .
I have a problem with one dynaco fm3 . The discriminator transformer is unalignable , I can't get less than -2,5v  on eyelet 32 so the signal does not pass ( normally there should be at least -8v)
The rf board , the if board and the multiplex section are working fine , the only problem seems to be the discriminator transformer itself .
I also opened the transformer , refreshed the solder joints and  tried to replace the pair of diodes inside the transformer  and the 33pF capacitor but  no success
Does anyone have any idea of what the problem should be and how to solve ?
Thank you , Antonio
Please refine your question
25.Jun.12 10:27
42 from 4017
Francisco Alemany Molina (E)
Articles: 33
Count of Thanks: 16
Hi Antonio, do not quite understand the problem, the FM does not work, you hear little or distorted?
regards
14.Jul.12 22:12
160 from 4017
Articles: 3
Count of Thanks: 23
Thank you for your reply , the tuner is working but the sound is weak and distorted , as the discriminator is un-alignable
All the rest of the tuner is working fine ,  RF , IF ,stereo decoder and the audio output are working , all the voltages through the tuner are correct
Thank you very much , best regards
