dynascan: 467; CRT Restorer/Analyzer
? dynascan: 467; CRT Restorer/Analyzer
22.May.13 17:19
Patrick Marinus (B)
Articles: 8
Count of Thanks: 10
I have the manual for this equipment and have scanned it the best i can. Compressing the pages to 300kB files is no problem when using JPEG. As soon as i try to save the pages as PNG the file size explodes to 1MB and more. PNG compression setting in IrFanview is set to 9. I tried many other features to reduce size: converting to grayscale, resize etc. How do i upload the manual ?
I also have the tube chart, i haven't even started to scan the document out of frustration...
Decrease color depth
22.May.13 18:15
15 von 2508
Emilio Ciardiello (I)
Articles: 527
Count of Thanks: 11
Emilio Ciardiello
Dear Patrick,
if the manual has no high resolution photos, I use to scan it as greyscale 256-level images. The next step is to enhance someway the image to the right contrast and resize it to a convenient size: 1200 wide for 2000 high is usually enough for easy reading. Then I decrease the color depth to 8, using the Floyd-Steinberg dithering option of IrfanView and save the resulting image using the best compression level, 9.
Hope that this way can help you.
Emilio
Complete success !
22.May.13 20:37
30 von 2508
Patrick Marinus (B)
Articles: 8
Count of Thanks: 10
Thank you for the info, Emilio.
I tried again with your tips in mind and this time it worked.
Now for scanning the tube chart...
Greetings,
Patrick
Better results without dithering
23.May.13 08:52
57 von 2508
Wolfgang Siegmund (D)
Articles: 48
Count of Thanks: 9
Wolfgang Siegmund
Hi Patrick, hi Emilio,
you may get even better results without dithering.
Best regards,
Wolfgang
Thanks for the tip !
23.May.13 14:48
80 von 2508
Patrick Marinus (B)
Articles: 8
Count of Thanks: 9
I still have a whole lot of documents to scan. I'll try all features to get a maximum result.
Best regards,
Patrick
