E463 (E463) with B5 socket and side contact
23.Oct.11 20:01
45
Georges Van Campenhout † 28.4.22 (B)
Articles: 202
Count of Thanks: 10
Good evening,
In a NSF H48A radio, I found a Philips E463 tube wtih a 5 pin B5 socket, and with a side contact.
Please see pictures.
What is the exact connection schema?
Possibly it is a wrongly marked E453?
24.Oct.11 20:16
45 von 4550
Articles: 1801
Count of Thanks: 6
Hello Georges,
I also think it is a wrongly marked E453. I never saw an E463 with that base, but we can not exclude this.
Anyway, it's almost impossible to have a base connection schema other then the E453. To be sure, you can check the wiring of the radio.
To be sure, what type it really is, you can only check this out by measurements with a tube meter.
At first you apply 250 V to anode and screen and - 22 V to grid 1. If the anode current then is around 36 mA, it must be an E463.
If the current is far less, then lower the grid 1 voltage to - 15 V. If the anode current is then around 24 mA, it will be an E453.
Best Regards, Jacob
24.Oct.11 20:40
48 von 4550
Articles: 202
Count of Thanks: 10
Good evening Jacob,
I tested the E463 twice with my AVO VCM163, with the pinning configuration of the E453:
pin 1 = a
pin2 = g1,
pins 3 & 4 = f
pin 5 = k
side screw contact = g2
Measurement settings were: Vf = 4V, Va and Vg2 = 250 V, Vg1= -22V
and this gives following readings:
Ia = 38 mA and S= 3mA/V
Conclusion: it has to be a E463, and it is in very good condition! The measured values seem to be better than the specs.
Careful inspection of the NSF H48A reveal that the original B7 tube socket has been replaced by a B5 socket.
Beste regards
Georges
04.Nov.11 09:23
115 von 4550
Articles: 1801
Count of Thanks: 13
Hello Georges,
this proves that the E463 was also produced as B5-base version, probably only in small amounts. Hence I introduced a page E463_5pin, where you can upload some pictures of this tube.
Best Regards, Jacob
